magnaflow- is off 4-6" from center?? how to ?
Originally Posted by YOMAN
just noticed that my magnaflow tail pipes (rearend) are toward passenger side i would said 4-6" off from center....kind of annoying
how to fix to center it ??
Thanks!
YOMAN!
Thanks!
YOMAN!
Wow; 4” to 6” off center is a lot. Are your rear hangers symmetrical with the truck centerline? If so, try getting under the truck while it is sitting on the ground and just loosen the clamps enough to move the pipes, then try to get them lined up. When the rear wheels are off the ground the springs get in the way of getting it all lined up. Depending on where your hangers are mounted to your frame you may have to do a little persuasion (bending) on the rear tailpipe hangers also. If the rear hangers are not close to symmetrical you my have to move one or both.
