snow+truck=loose
#32
#33
Originally Posted by bob800
Have a boss v-plow on mine no weight in the box no problems, stock tires 2nd winter in northern MN
Hey Bob800,
Where in Northern MN do you live? I'll be up in Grand Marias at the end of December. Anywhere near there? I love northern MN so much more than Minneapolis. But I don't think I could live there full time.
Duke
#34
Originally Posted by BalogUK
ok, so for conversation's sake, why are 'mt' tires so wide, if physically a skinnier tire is better ? is it just marketing looks?
so- kspencer, what would you say a good width & safe load rating is- my stock rugged trail's were just over 10" track width, but i have a feeling those treads would clog instantly, and become slicks... i can go drop my psi down in a bit- running at 50lbs now...will set it down to 40
In general, I go with about 10% less payload per additional inch in tread width from stock setup. Basically if the stock tires were 10" wide with a payload of 1700 lbs, then a 12" wide tire would safely haul a little less than 1400 lbs. I don't think that is going to be a problem when putting about 400-500 lbs in the bed for traction weight. I had the same problems with my 97 when I went to a larger tire setup. I just had to learn how to drive it safely in the snow. As I mentioned before, the weight per sq. inch of contact surface of the tire is what has changed. Adding weight over the axel or just a little in front of it will help recover some the handling disadvantages with larger tires. Plus, as may will agree, a mudder just does not grip packed snow. A finer "grid" type tread, as a snow tire has, has the ability to make many smaller indentations in the packed snow to afford better traction. As you have probably read throughout this thread, there are many different way to add "stable" weight to your bed. Best of luck.
#35
I would never use that water bag. NEVER. What do you get if the water isn’t frozen solid? You get 8lbs/g of water sloshing around in your bed. The trick to winter driving is constant control, having a heavy load that is uncontained is a bad idea.
400lbs isn’t too much but the problem is again; control. You have to answer for every lbs you have both moving and stopped. 400 extra pounds may help you get going but getting going isn’t the problem, the cruxes of the problem are control during turns and stops and lighter the better.
As far as no good snow tire for 18’s? I have BFG 285/65/18’s and they are wonderful in the snow. They worked flawlessly in 8 inches of snow in 4Lo getting up to our hunting cabin and worked just as well driving back to Denver on the Interstate as I passed numerous out of state morons up Eisenhower Tunnel.
I recommend using reasonable weight placed forward of the rear axle inline with the center of the truck and not expecting more than your tire can give.
#36
300wby,
As from your handle, I suspect that you bagged something this year?
#37
#38
Originally Posted by Marc Carpenter
Unfortunately, the wider the tire tread in snow, and mud, the worse the traction. The skinnier the tire, the better the traction because you don't get the floating effect you do with a wider tread..Skinnies don't look very good but they sure bite.. I had an old "high boy" F-100 4x4, at least thats what they were refered to in the early 70's when I lived in Oregon and I learned very quickly about the skinny tires in mud and snow. After a few times getting hung up on some isolated logging road, I went out and bought a set of them and never got in trouble again while out playing...
#39
#40
I would never use that water bag. NEVER. What do you get if the water isn’t frozen solid? You get 8lbs/g of water sloshing around in your bed. .
#41
Originally Posted by Josiah
Wider tires are far better than narrow, take the matt tracks for example, wider footprint, better weight distribution, you don't want to bog down in mud as thats when you have more mud to climb or push over, which is unwanted. You want to float on top and sling mud, higher void ratio's in lug patterns will allow the latter to be accomplished, a wider tire will allow the floating to be accomplished. Simple as that.
#42
Originally Posted by kd4crs
The Shur Trax water bags have baffles built in to them to prevent sloshing.
#43
okay guys, this is my first truck- previous was the jeep, so handling and snow is a bit different [understandably].
3.73 ls 4x4
every corner the backend flies loose regardless of being in 4 or not- well, less often in 4hi, but, still occurs... bed's empty- how much help would putting some bags of sand or so in the bed- if so, how much (lbs)? (ive got a tonneau, so im not worried about making a mess of it all-)
appreciate it-
jj
3.73 ls 4x4
appreciate it-
jj
#44
Originally Posted by F150 Duke
That may be true for mud but it's not true for snow. They're two different evils. A narrow (not talking bike tire width, just regular tire width, like stock) tire with a deep and aggressive tread is the best thing for snow. Use a wide tire in real snow and you'll get no where but in the ditch.
Exactly!
#45
Another Minnesota boy chiming in with his two cents on snow travel. I have 4 tubes of 60 lb sand in my truck. I have them stacked right next to both the wheel wells right on top of the axle. When I bought my last set of tires for my truck, Goodyear tossed in a tire sipe for each one at no additional cost. First set of tires I have ever had that were siped and I definitely notice that it helps with the traction on snow and ice. I have literally driven my truck on glare ice (we have been lacking some snow the past few winters...so the lakes get like glass in the winter......) and I have had no problems grabbing the "polished surface" when I head out across the lake to find that magical spot where I will drill my holes and catch my fish.
Biggest thing is to train yourself not to "stomp on it".....finess it a bit more in the winter.
BTW...Duke, I'd love to live in Northern MN also....but trying to make a living up there is definitely tough if you belong to corporate america.
