Help a Dummie out, Please!!!
I cannot for the life of me find the fuse panel location on my 05 SuperCrew. Yes, I read the owners manual. It says located below and to the right of the instrament panel. Remove trim panel. Well, I removed the large trim panel under the steering wheel, notta.
So where in the devil is this thing located and how do I get to it?
Jon
Jon
Jon
Jon
passenger side front by where your right foot is. remove plastic panel and its under there.
good luck
rob
Jon
Jon
Damn Ford, Ever thought of making use of the KISS Principal.......Keep It Simple Stupid.
The book should simply say fuse panel located behind the passenger side kick panel, period end description.
Many a thanks go out to all who assisted this old man in locating this.
Only problem was that after 35+ years of learning how to turn this old fat body down on the driver side of the floorboard and twisting to the left to work on the fuses. Now this old dog had to learn a new trick, lay on the passenger side floor on to my other shoulder and twist a whole new way.
And one other thing Ford, who in the hell thought of such a difficult location for the number 42 fuse, left turn and stop trailer light. You can't even see it behind the relay you hide it behind.
Jon
Jon
