2005 F150 HID Retrofit with LS430 Projectors - Pics Included!!
#47
#49
Originally Posted by RockPick
Hey Duke... how about a case of your favorite beer and a cold-crisp Franklin in your pocket to build me a set?!
I should have updated pics this week.
Duke
#51
#54
#55
#56
Thanks for the kudos. However, I can't take all of the acknowledgement for this project.
I had a lot of help from all the people at HIDForum.com who walked me through a lot of stuff and taught me a ton.
My main role in this project was research and design. I contracted out the actual work of making the projectors bi-xeon and doing a color/sharp cutoff modification.
I also contracted out the work of installing the projectors into the headlights.
I will be doing the install into the actual truck this weekend. The project will probably draw into next week if I encounter problems.
Hopefully I will have them by Saturday and I'll do a test to see if the wiring harness and projectors work the same as the stock headlights. If they do as this has been extensively planned and researched, then I'll do a test fit of the headlight into the truck. Most likely they metal behind the headlight will need to be trimed, primed and then painted to get a good fit and prevent rust. This step could take the better part of the day. Then I'll run the wiring harness and hide it to keep the compartment looking clean and OEM. I'll also have to mount the HID ballasts, (still haven't decided where to put them), anyone who installed HID kits feel free to chime in on where you put yours. Lastly the headlights will be installed and hooked up after they headlight lenses have been covered with 3M clear bra to protect them against pitting or other road debris.
Duke
Duke
#57
#58
#59
#60
