Tow Hooks or No Tow Hooks???
What do you think, guys?
I'm trying to decide if I should install a set of factory tow hooks on my truck. The overall theme for the truck is more of a "street" look (22" rims, 2" shackle drop in the rear end, etc...) and I realize that tow hooks don't often go on this style of truck. But I think a nice set of hooks (maybe even chromed?) would look pretty good -- what do you think?
Here is a front-end shot of my truck so you can kind of get a "feel" for what it might look like:
They will look great. I added a set to mine and they really seem to finish off the bumper (plus they are functional if you ever really needed them). After all you already have the places for them...they are just missing. I would go with factory black ones though because you don't want them to stand out.
A couple words of advice...don't worry about getting a 4wd valance. With a very little effort you can cut your factory one to accept the hooks and never know you cut it (I would take it off the truck to do it though...plus taking the valance off makes the hook install much easier). Second if you get the hooks make sure you get the factory nuts with them. The factory nuts are welded together on a plate so you can hold one with a bolt and start the other and tighten it. If you were using just regular bolts you will have to take the bumper off to start and tighten them.
Originally Posted by LsuSuperCrew
I just ordered some factory tow hooks from my dealer. The parts guy said that I'd be better off buying some bolts and nuts from a local supplier. Do you think it would make it that much easier if I went ahead and ordered the Ford nuts and bolts to?
How much are the Ford nuts and bolts? If they are less than $25 or $30 I wouldn't even consider not getting them.
Thanks, good advice. I think that's about what I was quoted per side. That's when it was suggested that I just use regular nuts and bolts. I'm gonna go check tommorrow, and probably order them.
How much were the hooks? I bought my hooks and nuts/bolts off ebay for around $60. I have no idea how much trouble the bumper is to take off but if the bolts are $30 per side that maybe a better option? If you take the bumper off you could use regular nuts.
I whish I had a pic of the factory nut assembly (its called a "threaded mounting plate" I think) so you would know what I was talking about.
Originally Posted by freddytran
Thinking about doing this mod too. Can someone snap a closeup of the tow hooks and front valance? You said don't bother with the 4x4 valance b/c you can cut the valance to accept the tow hooks? Just want to see what I'd be getting into before cutting it. Thanks.
I just cut my holes out following the outline thats already there from the factory using a dremal with a cutting wheel. Then went back with a sanding bit and smoothed the edge out. You would never know just by looking at it that it wasn't factory.
i just took mine off saved 11lbs cause im not going to use them to pull anymore chebys out of the ditch
https://www.f150online.com/galleries...w.cfm?num=9331
