Question on adding a power outlet...
Wandering if anyone has added a additional power point to their 150. With cell phones and all the other gadgets I play with I find that I sometime need another 12 volt outlet. I would like to add one just to the left of the lighter outlet. My cig lighter is on the far left of the dash module so it would be mounted on the grey part of the dash. There seems to be enough room behind the dash for it but I don't know what outlet I might need. Anybody have any ideas or experience with this?
how about getting one of those splitters that have 2 or 4 outlets. They have em at walmart, etc? But if you want the clean look mounting a permanant one is pretty easy. Just try to use one of the removable panels to cut through not the actual dash (incase you ever want to delete it). Then run a wire to the fuse box.
