Wiring Options For Aftermarket Lights
Thanks for sharing the wiring diagram! You can also hook the relay up WITHOUT a switch if you want your driving lights to come on all of the time with your high beams. I wired mine that way.
Another caution. Be careful how you "tap" into the high beam wire for your relay trigger. Hint: If all you're using is a pocket knife and bubble gum, you're doing it wrong. You can really mess up an expensive factory wiring harness with Redneck wiring techniqes - which I've seen way to many times as of late.
