Let me try here,no feedback in audio.
I bought a Alpine V12 4 Channel amp, size 13x8.5 and it looks a little to big to put it under the seats with the brackets and wires so would a good alternate location be under the rear seat where the jack is mounted if I remove it? I would like to keep the rear driver side clear for a potential sub box down the road. This is my first aftermarket amp and so Im kind of clueless.
Thanks for the help
05' Silver/DSG-FS/SC FX4
"Kick the Tires and Light the Fires."
https://www.f150online.com/galleries/....cfm?gnum=4714
Thanks for the help
Originally Posted by 02Thunder
Brew's spot, or behind the back seat would both work. Best of luck.
joe
joe
With the amp being 13x8.5 it looks like it would fit in the jack location nicely. Keep the longer portion of the back seat open for a 10" sub box down the road. Then where would I mount that amp?
Maybe the amp for the door speakers on the passenger side behind the rear seat and when I get the amp for the sub put it behind the rear seat drivers side? Does that seem like the logical thing to do? Thanks a bunch. I cant wait to get everything installed tomorrow, should be a wee bit better then stock,lol.
if the amp isnt running a sub currently, check out your dash, my alpine v12 mrv-F345 4ch. is in the dash- fits fine- pull out your center portion where the head unit is, so you can access the space-
its just tapped in there with a couple screws- off-road with it and its not knocked out, no crappy signal disconnect - gets plenty of air,etc
Justin
Justin
Justin
Justin
yea theres a ton of room, the initial fit is tight- getting it thru the opening, but once in there, youve got a friggin bat-cave. sorry, no pics to show ya...didnt have the memory card in it that day- arg.
Originally Posted by AirborneRacer
So you dont see a problem with ventilation if it was in there? And there is nothing to tinker with on these amps once there setup? Just tuck it away and dont worry? Thanks.
Also, once the amp is installed and tested and sound matched to the rest of the system there should be no need to be messing with it any longer.
Hope that helps
Originally Posted by Doo2theSea
Yes, it will be very well ventilated, I have a blaupunkt video cross connect in there, basically my Alpine In dash (only the face is outside - where the ashtray was), tons of cabling, my PIE.....and there is still TONS of room in there....
Hope that helps
Hope that helps
