Lariat Cluster Swap is Finished!
Originally Posted by AirborneRacer
Looks good. I bought the SS overlay also for my FX4 and cant wait to install it. By the picture on the box still looks the same at night lite up like the OEM one.
Originally Posted by bigdummy
I am interested in the cluster if it will work. I have the XL and it only has the MPH on it (no tach or compass or temp thing). I would love to change it out if I could. Any thoughts?
Well, I know it will swap, but the question is, what will work? Power window and such are controlled in the cluster, the 06 displays temp/direction, so i question whether that would work. I know 06 STX's and XL's with manual transmissions have a tach, so I presume that should work. I guess the only real way to know is to swap one. Hopefully you can find a "loner cluster" before you buy and try. Good luck! Ron
Originally Posted by dclements
I would love to do that in my truck. I actually posted a couple days ago wondering if anyone has done it. Could you post the detailed instructions. I'm soooo excited. You have no... idea.
great! thanks
great! thanks
Originally Posted by Motopro292
Swapping the clusters out is the easy part. 2 screws on lower finish panel, 2 holding cluster bezel, then unsnap it (just gently pull the panel towards you) 4 screws hold the cluster in. Two connectors on the top of the cluster, just unlatch them and those are out. Then lift it a little, reach under it and squeeze the tabs that hold the gear shift indicator in then remove. That's it. as far as wiringing the cluster so the message center will work, that's fairly easy as well. I can give you detailed instructions if you're going to do it. It requires very little work, just a little time as you want to make sure everything goes where it's suppose to. Plus you need a couple of connectors that you need to get from the dealer or rob them out of a salvage cluster harness. Ron
Ok, I'll take you up on the offer of detailed instructions. please send me a pm
i can't send a message... maybe because i'm just a Junior? email me at motopro292@aol.com. I also have the factory connectors with about 6 inches of wire. Lots of them! lol... I may put a kit together with this other Larial Cluster I have to sell...
mail sent.
