Lariat Cluster Swap is Finished!
Finally finished the Lariat cluster swap! Added US Speedo stainless overlays and I think it turned out great. Wired and installed the message center control as well. Done is done!
https://www.f150online.com/galleries....cfm?gnum=7512
Which part? Swapping the cluster is easy, as long as you have your vehicle's parameters loaded into it. I had to add two wires/connectors to one of the harness plugs, tap into 2 others, cut a hole in my bezel and Presto! Lariat cluster with functional message center. The Stainless faces were probably the hardest part, making sure they lined up PERFECTLY so the white didn't show through. If you're serious about doing that, let me know. I have another Lariat Cluster with about 6k on it. Rond
Originally Posted by nu-supercrew
I like the upgrade. I have an XLT which has the odometer / direction and temperature. If I get a Lariat or FX4 cluster (have it re-set), add the the three switch group, and that's it? How difficult is it to remove the cluster?
