E-Fans in
#32
Originally Posted by misato
I was worried about rub through on my dakota..but I sold it after 2yrs of having them on. it seems that all of them mount that way.. anyone make some actual brackets? not the poke through kind?
#33
#35
E-fans are going to be my next mod, and I was also worried about the "pins thru the fins" setup. IMO, it's never a good idea to hang anything from an aluminum rad core. It's just asking for trouble. Not only that, but when you slap those two 16" fans direct to the core, you're basically rendering around 25% of your rad useless.
I'm in the process of laying out a shroud that uses the stock shroud mount locations (on the tanks). All I need to do to finish is measure the mount hole locations on the two 16", 2700 CFM Zirgos I have on order.
With the fans, controller, and shroud, I should have around $180 total in the setup. (That figure includes hoping that the sheet metal supplier I deal with at work will hook me up with a freebe )
E...
E...
#37
you need something like this...
http://cgi.ebay.com/ebaymotors/Flex-...QQcmdZViewItem
i have a mechanical controller in my ranger with the same type of sensor in the upper rad hose. works good.
and i'm also not a fan of installing anything TO my rad. that's what fabrication is for.
#38
Originally Posted by FX4 Matt
I'll sit and wait on your pics and install time thats a great price less that 200$!
I'll try to remember to take pics during the install.
E...
#40
Is this the controller you are using. http://www.madenterprise.com/fan_control.htm
Originally Posted by Matt 05'FX4
I have a dual 14" setup with a mad controller and I love em! Gas mileage was probably the biggest notable difference. I have a switch to manually turn em on, here is a pic.....
#43
I have the MArk8/tbird fan in my truck with the mad controller. Works great. I am going to the spal controller when i get off my lazy tail so it will run all 50% all the time to help out the AC. Plus i dont want the fan to start and stop all the time. But it works great so far... FAn was $150 shipped and controller was about $100 shipped.
#45
E...
E...
