Problem with Left Rear Window!
rear window switch, you can test it easily by popping it out and popping the other side out (if the other side is known to operate properly) and using the known good switch to see if it works on the side that isn't working now. Unless like fx4 said if your under warranty take it to the dealer. My guess is a bad switch
