I got a flat tire......
they said they checked the valve stem beacuse that is known to cause the most leaks on newer tires but they said it was fine. Im not sure if they put it in water but I guess Ill try that if I cant figure it out. Actually it is a very slow leak so will you be able to see the leak with water even though it is that slow?
Originally Posted by Silver05screw
What we used to do when i worked in a shop was get a spray bottle and fill it up with bubbles like little kids play with and spray it a the tire and if you see bubbles forming that is were the leak is.
I hate living on a gravel road
