drop kit
drop kit
djm or ground force? the ground force uses the stock arms and shorter/stiffer coils up front and new leafs out back. the djm has the modified arms up front, and hangers/shackles out back. the djm is 600 and the ground force is 800. the gf would gove a much sportier ride, since it has stiffer springs. what are you using for your 2/4 drop ?
I have the ground force 2/4 and absolutely love it, I have also added a rear sway bar and custom made rear traction bars. This sytem handles like a mustang GT I love it couldnt be any happier. I picked this kit because I was looking at handling not the dropped in the weeds look so if you are after handling the ground force kit is the way to go, just be prepared for the driver side front leaf spring bolt it is a pita. When I do my wifes truck I am going to buy a replacement bolt and cut the old one out instead of removing the gas tank. Good luck on what ever kit you choose.
