Weird electrical problems.....
I don't know why or how but I now have some serious Gremlins in my truck.
It seems that for no reason at all the radio will turn on, even if it is turned off, anytime it desires to..Thats right, the power comes on by itself when the truck is shut off.
Thats not all....When I hit the locks and go to close the door, it unlocks before the door closes..
And to further complicate things, I found the battery dead this morning, and once I put the charger on it the parking lights came on..
Anyone have any ideas????
I am actually stumped on this one....
Example. --- Radio just turns on. = Truck is getting ingnition power.
Example 2---Doors unlock when door is closed after pressing unlock button =
Truck thinks the key is in the ignition and on.
Do you have a Command start installed? If so i would have to guess that something is shorting power to your ignition wires either inside the command start box itself or one of the wires has rubbed though under you dash on your steering column.
If you don't have a command start then it could be a similar problem with one of the wires under the steering column shorting with a power wire.
Through process of elimination I have narrowed the electrical issue down to the delay, when you turn off the vehicle and the radio stays on until the door is opened. My radio sometimes stays on when the vehcile is turned off and the door is opened. When this occurs even if I turn the raido off, the clock stays light, and the radio will randomly turn itself on.
Guest
Posts: n/a
