2004 Xlt Lots Of Problems
The front end shakes between 50-55 mph and has done so since 1,100 miles. I've had this truck in the shop several times. I regularly rotate/balance/align the tires nothing helped. At 26k miles, my tires were badly worn and I had to replace them ($650 total out of my pocket).
During my numerous visits, they've replaced: ring gear & pinion, throttle body, battery, brakes, and as of yesterday the drive shaft!
My neighbor up the street had the same problems with his '04 F150 and Ford actually replaced the vehicle because they could never fix it!
Has anyone else had these problems with an '04 model?????
I love my truck, but I'm worried that I may have a lemon. I'm thinking of trading her in.
Frustrated in Florida
If you did rotate and balance your tires regularly, and they still wore abnormally, they should have been replaced under the extended 3/36 tire warranty.
Don't give up, I fought Ford for a year before they bought my 04 back for the same problem you are having.Look up your state's lemon laws. Mine was 3 attempts for a single problem.Be sure and save all your documentation. Make your dealer close out your ticket each visit. They may try to keep a single ticket open so that it looks like you have only been in for the problem once.
Also try to have your dealer Road force balance your tires. If they are out of range they should be replaced for free.
If your dealer is uncooperative, go to another one.
I own a 04 XLT 5.4L and it now has 48K miles. Its been in service since 10/03 and I have never had a suspension or drivetrain problem. No vibrations, no dead batteries, or bad breaks. So not all 04's are bad. So far the only thing that has gone wrong is the window regulator in the driver's door. I recently (yesterday) replaced the stock Hankook tires, which still had 5/32nds of tread remaining, with Nitto Terra Grapplers.
Ox
Ox
I had mine replaced from ford at 35k miles it was ~1100 bucks covered under warrenty. That was on my 04 too.
Originally Posted by TeckBargins
Ford changed coverage on tires... 3 yrs/ 36k miles warrenty.
There is a TSB somewhere about the rack. I believe tightening the rack itself is part of it, and taking up backlash is the second. Either way, we do it here sometimes to avoid the dealership hum-drum and have been 99% successful in eliminating the steering wheel wobble, or 'nibble'. Also, it couldn't hurt to dynamic balance the tires, or road force and check for run-out or a bad tire. Static balancing is worthless, but very common. These trucks usually are out of spec even new (a good number of them anyway) concerning alignment, but that's usually just 'toe', not caster or camber, and easily rectified. More aggressive (ATS, etc) tires wear, or 'chop' quicker than normal street tread if there is a toe issue. Try tightening the rack where it mounts to the truck and check the tires and wheels with a decent dynamic/road force balance. Hope this helps......
