Just got new Terra Grapplers
Tires are 325/50/22 (35" overall diameter) Terra Grapplers on 22x9.5 Forte Shooters with +35mm. Rubs a little on the frame at full lock, no rubbing at all on flares. Rear is stock with 2.5 daystar in front.
Hope you enjoy!
Sorry for the crappy pics, I don't have a digital camera so I had to scan in some pics from a disposable.
Hope you enjoy!
I do feel a lot from the road, but I think that is mostly because of the weight of the wheel/tire combo, probably about 100lbs a piece. I've been running 305/40's on these wheels for the last 6months, so the ride is better than the old tires. As far as cornering, I'm still feeling that out, since I'm used to the 40 series tires without the leveling kit and without the rear blocks, which is what my old setup was. With that setup, the truck cornered like mad, I actually pulled on a '95 Mustang on a long, sweeping on-ramp one day. These are a little worse in the turns, but so far they feel pretty good.
Hey this is a good question for both ford141 and oxlander, since you guys both have new Terra Grapplers. How do these tires compare to what you had before in regards to tire noise at highway speed. Also was wondering (more for oxlander) how the tires ride compared to the old stock tires?--DIY
You should love the Terra Grapplers, I know that I do! Plus they look really nice under you truck.
DIY, I also upgraded from the stock Goodyears AT/S's to the Terra Grapplers back in late March. There is very little more road noise, IMO. But I am also used to listening to the M/T's under my work truck howl, so I don't pay very much attention to road noise.
I was really suprised that there is'nt any road noise from this tire. In fact on Friday I got on the interstate fully expecting to hear the nortorious hum associated with large lug tires, but there was'nt any. Very, very quiet. Ride quailty is a little bit stiffer than the stock P235/70R17s. For example, the stock tires used to squeel alot whenever I would corner in a parking lot like Wal-mart. I think this was due to the 2 ply sidewall construction which provided a smooth, soft ride but less responsive handling. Now with the Nittos the squeel is gone. Initially the tire shop that mounted my tires inflated them to 40psi but that felt a little "mushy" to me when cornering. I now have them at 50psi and they feel just right.
Ox
Don't know how I missed this thread. But I like the bigger tires on the 22s. It stinks that they rub the frame but I'm suprised we can even get that far.
I always wanted to see what 35s looked like on 22 inch rims.
I want to put a suspension lift on in a couple years when it's no longer a daily driver. I was thinking about keeping my 22s and then wrapping some 35s on them, but after seeing this I think they'd definitely need 37s to look right.
Duke
Duke
Thanks. How about the ride? Are they significantly stiffer?--DIY
Nice truck ford141!! looks good
