When do you change the oil on the 4R75E?
Originally Posted by Quintin
The PCV valve is electronically controlled and heated.
this is what the manual states.
150,000 miles
❑ Change engine oil and replace oil filter.
❑ Inspect tires for wear and rotate.
❑ Inspect brake pads/shoes/rotors/drums, brake
lines & hoses, and parking brake system.
❑ Inspect wheel ends for endplay and noise.
❑ Inspect engine cooling system and hoses.
❑ Change Motorcraft Premium Gold Engine Coolant
(see exceptions page 46 and record page 48).
❑ Inspect exhaust system and heat shields.
❑ Inspect steering linkage, ball joints, suspension and,
if equipped, half shafts, driveshaft and U-joints.
❑ Replace engine air filter.
❑ Replace fuel filter (see page 47).
❑ Replace cabin air filter, if equipped.
❑ Change automatic transmission/transaxle fluid
and filter (except CVT; filter not required on
CD4E).
❑ Change rear axle lubricant on all rear wheel
drive (RWD) vehicles (see pages 42 and
46).
❑ Replace accessory drive belt(s) (if not replaced
within last 100,000 miles).
❑ Replace climate-controlled seat filters if equipped
(Navigator, Expedition, and Aviator).
❑ Inspect PCV for flow (5.4L 3V and 6.8L 3V
engines).
❑ Lubricate 4X2 ball joints and steering linkage if
equipped with zerk fittings.
❑ Replace 4X2 wheel bearings and grease seals,
lubricate and adjust bearings.
❑ Inspect and lubricate 4X4 front axle shaft U-joints
(F250/350/450/550 and Excursion).
❑ Change front axle lubricant (4X4 only).
❑ Change transfer case fluid (4X4 only).
❑ Multi-point inspection (recommended)
heres what it states for the 30k mark.
30,000 miles
and, if equipped, halfshafts, driveshaft and
U-joints.
❑ Change automatic transmission fluid on vehicles
equipped with the Torqshift and 4R100
transmissions. Replace the remote filter element
on the vehicles equipped with the Torqshift
transmission. Inspect automatic
transmission/transaxle fluid level on all other
vehicles, if equipped with dipstick. Consult your
dealer for your particular requirements.
from what i gather i dont have to change my fluid untill 150k but i wanted to see what you people thought.
I think common sense makes sense. If your fluid/oil is getting brown or smells odd then change it. It is like them saying the spark plugs last 100k but if your injectors leak and foul them do they last 100K? If your pulling a trailer that is max weight is your tranny going to last 150K? What Quintin said makes sense if you want to CYA
I am having mine changed with Mobil 1 ***AT*******(lets be helpfull and not bring up oil..fluid bs..we knew what he meant) at approx. 65000 on Tuesday. I am also having Slick 50 Trans stuff put in it as well. I will swear on my dying bed by the Slick 50 stuff it works wonders.
My thought is an ounce of prevention..I forgot the rest but I am Covering my Asentialls..
I changed mine out around 33K mi. There was quite a bit of metal on the magnet and a few small pieces sitting on the bottom of the pan. I know this is normal from break in, so get that fluid out ASAP. I went one step further, and got the aluminum B&M deep pan with cooling fins and a drain plug.($110 from summit) I also used a qt. of Lucas trans fluid additive as well. Please stop splitting hairs with the "oil" and "fluid" debate. Thanks
