F.Y.I Something I learned about our transmissions.
Originally Posted by Josiah
Please explain how downshifting is killing the transmission?
Since the computer took over, I shift the tranny with my right foot. I've never seen a reason to shift it. I used to shift my c4 all the time. Even hit reverse instead of neutral. That was interesting.
Either the C4 or the C6 had a second gear start. If you put one in second from a stop, you had second. If you put the other in second from a stop, it would shift up from first to second, then it would stop there.
If you want to have some fun with the tranny, go WOT from a dead stop. Lift completely just before it shifts and then stab it again. Nice, firm and high rpm 1-2 shift.
Here ya go...
https://www.f150online.com/forums/sh...89&postcount=5
Hope this helps.
How's that Edge workin' for ya?
Cheers
Bubba
Originally Posted by MGDfan
Hi J;
Here ya go...
Hope this helps.
Cheers
Bubba
Here ya go...
Hope this helps.
Cheers
Bubba
Lastly, around town the edge behaves far better than the Troyer tunes. The XCal2 would constantly have me shifting @ 3000+ RPM's. When A N T H O N Y bought it from me, I had to show him. He too was scratching his head. I just really did not like the way my pedal felt with the XCal2, I would say that is the major difference in switching from the XCal2 to the Edge.
Thanks for the update J.
I am glad everything worked out for you. Being happy is the most important thing. You've had your share of problems for sure.
On the fans - have you considered another brand of controller? DCControl or SPAL? You overheating with 2 16" fans is very unusual - try Redline Water Wetter, possibly have your cooling system checked, and also possibly use a shroud for the fans ( if you haven't already considered those things) ...
Take care.
Cheers
Bubba
Take care.
Cheers
Bubba
I think the confusion is the idiot proofing done on a lot of computer controlled transmissions of the past. Most of them would not allow 2nd to be 2nd until the computer decided it was ok.
Thankfully 2 means 2, 1 means 1 on these trucks. What I can't stand is the way it readjusts the throttle response.
As for shifting on the fly, engine braking is a good thing. Of course I supposed there are idiots who will try to do it at 60mph.
The computer control/tranny connection on these trucks is definitley different.
I can stab the throttle on mine from a dead stop in D and not so much as chirp a tire. I can pull it down into 1 and then stab the throttle at a dead stop and it will slide me into a curb or ditch if I'm not careful.
You would think that taking off at WOT is the same either way. There is definitely something going on with the shift or traction control that says otherwise though.
i haven't tried to spin them in 1st gear, but i think my experience would be the opposite of yours
i can break them loose at will in drive--but judging from my experience with 1st gear, the electronic throttle control requires me to put a lot more travel into the pedal for an equivalent amount of throttle
Take care.
Cheers
Bubba
Take care.
Cheers
Bubba
Be sure to check out my HID writeup, I'll throw a pic of the fuse in there.
