Part No. Request
Someone else that actually works for a dealer or Ford can correct me, but the parts manual I have doesn't show a Chrome version for a RegCab or a Crew Cab, so that can't be right. The only ones that specifically say Chrome are in the SuperCab page, and they list the following numbers:
Pre-Dec'05
LH - 6L3Z-18219A65-CAA
RH - 6L3Z-18219A64-CAA
After Dec'05, the parts numbers are the same except with one less "A" at the end.
But again, I would certainly verify those numbers will work with your RegCab before ordering them.
Pre-Dec'05
6L3Z-16219A65-CA Left side. MSRP $110.37
6L3Z-16219A64-CAA Right side " " $110.85
These are the numbers for a Crew Cab w/power locks. It does not specify chrome or black. But logically A S_Crew w power has chrome handles. And internal door parts for reg cabs and crews are the same. Some Super Cab parts are different due to the door being larger/longer. These handles are different between Supercabs and Regcabs.
I'm correcting the way I implied the handles are different. From FORD, when you buy those handles from the dealer, they come with the cable and latch as well. Which, even for me working at a dealer I think that's BS to sell it that way!!!
But that's what makes the different listings for the supercab and regcab.
But Since you only need the handle, you can order a supercab setup, which are cheaper by about $35-40 dollars per side, and just dissconnect the handle from the cable and install just the handle.
The part numbers quoted by BIRDMAN are correct for supercabs
The part numbers I shared are correct for Reg and Screws.
I hope this helps. Not to confuse anyone like I did myself for a moment.
