Spider gears torn up
I just went to the gear place and they popped the cover off and said that the spider gears were torn up and that had a chain reaction. I asked the guy what I could do strengthen it and said I could put a lsd in there. So right now that is the plan, they are going to change the spider gear out and put a lsd in there. He said ballpark around $800
Originally Posted by Josiah
I believe an LS would increase strain placed on your diff. Do you have the 4.6L? I'm guessing you damaged an 8.8 and not a 9.75. The freeway is the last place I'd imagine you nading the spiders.
I think they were just trying to sell you a limited slip carrier unit by saying it would decrease the strain. You should definitely just swap in the 9.75 axle, it shouldn't be too bad if you get it from a wreck. Would be a direct bolt in I believe.
Originally Posted by texaspyro21
It takes the power from the wheel that is slipping and sends it to the one that has traction in a nutshell. Hence Limited Slip. instead of doing a one wheel burnout in one spot, you get a short two wheel burn out that launches you.
ok i got regeared 4.56, i can spin then form a stomp, do i have lsd?
