Putting new Brakes on the F150?
Originally Posted by slvrf150fx4
Well the new brakes are on. It was very easy and they look and stop great. I went with the power slot rotors and hawk pads. Also i painted the Calipers black. Also I took my bug sheild off and put a new grill on the truck. Please let me know what everyone thinks about the changes. Theres more pics in my gallery.
Originally Posted by ScrapinFrame
Not to get off track. I want to put some better rotors on my truck. And I've recently been finding some cheaper. But why des it seem like the 4x4 rotors are cheaper than the 2wd ones? Baer replacements are the ones i'm talking about. $180 per rotor, thats for cross drlled and slotted.
Alternative source for High Torque Torque Wrench
Does your front hubs have a big nut holding everything together, something like a 35 or 36mm? If so, you will HAVE to replace them. They are single use only.
Update: I researched a past thread of mine. The part number for the nut is 6L3Z-3C294-AA. The cheapest I found it was at brakeco.com for $15.98 each. The nut is a 36mm torqued to 295 lb/ft.
You can find a torque wrench at harbor freight for about $80 that will go up to 300 lb/ft. It is a 3/4 wrench, sp you will need an adapter to fit the 1/2" socket.
This is for a 2004 2wd truck. Numbers and specs might be different for different years.
