Threw a code.......
P0506 in my book is called out as "idle air control system rpm lower then expected"
I'm assuming your "Valve duty cycle lower then expected" refers to an old IAC valve setup which our trucks don't have.
This code could be because somehow extra air is getting into your engine. Like lose connections or holes. Have you messed with the intake at all?
-ii
-ii
-ii
-ii
Originally Posted by TNC
Air leaks usually cause a high idle. You'd probably start getting lean codes as well if that were the case. That being said, I looked up the code and it says the throttle body or a vacuum leak. So......
