Cam phaser repair? Is it long term fix?
Originally Posted by Stealth
Hey, bud. I'm only trying to help you. I feel for your engine problems, but STOP biting my head off already.
The lack of using an anti drainback oil filter HAS cured some people's startup noise, though it seems not the case in your situation.
I'm curious, between guys that go to the dealer for service and the guys that go the xtra mile and use high end everything (inc oil filters) what % of 3v's out there would not have the anti-drainback valve? Might be higher than I first thought given all the cheap do-it yourselfers who go to local autoparts store for cheapest filter/oil combo???
Originally Posted by A199578
what does this cam phaser noise sound like and when does it do it? My truck makes like a quick rattling noise at startup for the first start of the day and goes away in 1 to 2 seconds and i never hear it again till the next day at startup. Is that a cam phaser noise?
Mine makes noise, but a very trustworthy ASE Ford mechanic friend of mine said it's fine after I brought my truck in for the cam phaser repair. I only did so because of the horror stories I read online, mostly here. Personally, I think the cam phaser repair is like snake oil.
Originally Posted by TNC
I think you're right for the most part. I haven't heard a lot of stories about the phaser ticking and then the engine exploding. I have it. Mine ticks, along the lines of a quiet diesel after warmup. Truck sounds great cold. Unless it's a warranty fix, I'm leaving it alone.
Over a year ago, Quintin said that the phaser noise does not hurt the engine at all. After listening to mine since the day I bought it, I have not broken anything on top. I agree, this fix is only for a little noise (piece of mind) and does not damage a thing. I would say it is a big waste of money, and I have never heard of engine failure due to a noisy cam phaser.
Originally Posted by Smok][n
i have a intermittent knock at idle. its pretty loud like a rod knock... but it only does it once or twice, and nothing for 5-30 seconds then again. does this sound like what you guys expereienced?
also, on the ford parts site there is no "cam phaser" but the "cam gears" for the 5.4 is like 5 times as much as the 4.2 or 4.6. is this the cam phaser?
Cam gear = cam phaser= VCT on the 5.4L 3V.
Watch episode 22 here guys. It will explain it all.
V
V
V
http://flatratetech.com/index.php?categoryid=12&
I had my phasers replaced and the ticking started back up after 2 weeks but a little quieter now.
Also have it on startup as well. (watch the video)
Hope it helps, explained a lot to me. I know this thread is old right now but others will stop by with the same questions I suppose.
V
V
V
V
V
V
V
V
V
