Difference between having Limited slip and not??
#31
#33
Originally Posted by Tbird69
I don't understand what your trying to get to "engage"? A limited slip is always working. There's a clutch pack and a spring that keeps pressure on the clutches which ties both rear axles together at all times. The "limited slip" part comes when you turn. The spring maintains enough pressure to keep power to both wheels but not so much that one wheel can't turn faster when needed to make a turn. This is why it's so important to use the correct amount of friction modifier to allow the clutches to slip when needed. If you have one wheel on ice and the other on dry pavement you can overpower the clutch pack if you stomp the throttle, causing the wheel on the ice to spin while the other stays stationary. Some power will still transfer over just not enough to be noticeable.
#34
Originally Posted by mbogosia
I guess I just worded it wrong. Seems like it should have been pretty easy to understand what I was saying. I was trying to make one wheel slip and then get the limited slip to work and have the other wheel with traction take over.
#35
