ok i want the toyo m/t...35x12.5x20 (oem wheel) but how many miles out of em?
how long do they last...i only drive on the road...no offroad...tho i may go occasionally hunting season etc...especially if i have these tires ....but i drive alot on the road....so i need somthing thats gonna last a few miles...also hows the noise?? i've been searching for an hour but can't get all my q's answered...thanks
I bet you'll be able to get at least 30,000+ miles out of them. Proper air pressure, alignment and rotating them as much as possible will help you get the most out of them. The noise isn't ANYTHING to be worried about, they're a very quiet M/T.
They'll fit fine, a little trimming but nothing major.
Originally Posted by 07screw
The noise isnt bad but i dont think they will fit
Why not go with a nice aggressive A/T? I'm biased towards BFG A/T's, but there are others out there that are good as well. A/T's typically give you more treadlife while still giving you an aggresive look and better performance off-road than a street-performance tire. Do your homework and you will find what your looking for. Although I must say for a M/T the TOYO is an excellent pick for all the above mentioned reasons.
Originally Posted by nuclearthreat54
How do you plan on fitting them? Get 33s if you dont get a suspension lift max.
Oh and what size OEM rim do you have? 35s on stock 18s would probably look awkward. Just throwing that out there.
Oh and I like the look. .
yeah i have a 2" as...did some searching on here and a few ppl are running it....only minor rubbing at full lock...and the bfg's are nice but alot more expensive then the toyos....and the toyos look alot meaner...so if they are cheaper and meaner looking and are smooth on the road...y not
Good point. But I will get close to twice the tread life on mine as you will on the M/T's. But I will probably get tired of them before then, so I'm on your side!
Cooper also makes a SST or something like that name that looks almost identical to the toyos and is a bit cheaper, like $50 a tire cheaper. i will probably try those next time to save a few dollars.
get them and enjoy them, mine barely rub at full turn..
rob
