i had the front wheel of my 4x4 off the ground and the front drive shaft turns with the tire.is this normal with it not in 4 wheel drive?
thanks for any info
If you did this with the engine off, yes. If engine on and not in 4x4, no. The IWE's (hubs) have a default of locked with no vacuum. Once the engine is started, vacuum is sent to the IWE and it is unlocked.
and because of the added weight of the front drivetrain
you know i dont think the wieght is even that big of a deal well i suppose the T-case is pretty heavy but the front differential cant weigh more than 40lbs. i held the thing with one arm.
