Installing Rear Glass
If it's new, it'll already have sealer on it. You'll have to partially lower the headliner to get to the top row of nuts, but otherwise it's fairly straight forward. Bribe a couple buddies to hold the window in place from the bed side as you start and tighten the nuts that hold it.
What the hell happened to the original window?
My CB antenna got knocked off by a tree limb and fell down and busted one section out of the glass.
Originally Posted by captain morgan8
It came off new truck at the dealership that a guy had ordered but he wanted a power sliding window so they switched em out. When I took my sliding window out I noticed it was sealed with what looked like a double sided padding/sealant of some sort. Should I try to re-seal the glass myself or take it to have it done professionally? I'm gonna call and get a price quote tomorrow but what can I expect the price range to be in?
This was from an earlier post I answered some time ago:
I just installed a power slider a month ago and its fairly straight forward. If you know how to remove the rear seat back, plastic side trim and aft roof liner, its all cake from there on. Leave your truck sitting out in the hot sun for a few hours to loosen up the adhesive and then begin removing the 16 or so nuts holding the window in. Have someone in the bed and start pushing out near a corner until you break it loose. Have your in-bed helper keep slight pressure on the glass while removing and watch out for the black adhesive which will be stringing everywhere.
I left the old, soft adhesive on the body so as to be sure it wouldn't leak when mating to the new window. Glue will already be installed on new window protected by plastic. Remove the protective plastic and install in reverse. Secure nuts in a criss-cross pattern to avoid uneven pressure on the glass.
you can install it yourself or get a glass shop to install it, If you do it, you need a 7mm or 8mm round butyl surround, foam core tape kit.. some installers call it a everseal kit, should be avalabile at any good autoglass shop.... can also be ordered from ford dealer...
Install is striat forward, clean off all old kit from pinchweld and glass, install kit on glass starting center bottom, use two people to set glass in your truck lining up on studs, tighten all nut to 30 in lbs from center outward, then recheck all when done....
need any more info, PM me....
Tim (Master AutoGlass Installer)
Binswanger Glass Co.
Fixed or sliding glass won't stop a brick, so I dunno about the added security part. I like the fixed rear window 'cause it's one less thing to go wrong, and I like having a rear defroster.
