CA-670 Keypad Wires
pretty sure i still have the instructions from travis in my email...i could email you them if you would like, i believe they are in a pdf.
here are the 3 wires for the keyless entry pad...let me know if you want the entire instruction packet...
Connect your LIGHT BLUE with RED STRIPE wire to the pink with black strip wire. This wire shows 12 volts or turns thetest light on when you hit lock on your factory keyless key fob.
Connect your LIGHT BLUE with BLACK STRIPE wire to the red with orange stripe wire. This wire shows 12 volts orturns the test light on when you hit unlock the first time on your factory keyless key fob.
Connect your LIGHT BLUE with GREEN STRIPE wire to the pink with orange stripe wire located in the driver’s side reardoor sill plate. This wire will show 12 volts or turns the test light on when you hit unlock the second time on your factorykeyless key fob. To make sure this wire is correct you should hit lock on the key fob then hit unlock twice. You will mostlikely need to extend this wire.
