Squeeky belt after wash and low voltage
Squeel from belt after wash and low voltage
Does anybody here get a temporary squeel from their belt after going through a car wash, or if the snow gets through the front grille the right way?
I've had a couple of instances lately with car washes (ones that spray underneath) and during a snowstorm where IMO water/snow got through and hit the serpentine belt. What happened was the voltage dropped with a squeel coming from the belt. This was at night and the lights dimmed and fan for the heater cut down to about half power. It was only tempory, for about 3 seconds and then it seemed like the belt caught, the squeek stopped, the pully caught and voltage was back to norm.
Is this a common gremlin or should I take it in? When I'm running across the lakes this icefishing season and I'm traveling through some heavy slush, I don't want to run into any issues while out there on the lake with water spraying all over the place.
It has happened now about 3 times.
Originally Posted by birddog_61
I would put a Gatorback belt on, when I got my tuner I had a belt squeak on 1-2 up shifts I switched to the gatorback and no problems. IMHO the Gatorback is a much better belt than Ford will put on there.
Blake
Blake
They also greased the slip yoke while I was there.
