2007 Floor Shifter Knob...
2007 Floor Shifter ****...
I am looking to swap out the plastic one in my Lariat for the leather wraped one in the Mark LT and was just wondering if anybody here has done this and how to go about takeing off the origonal and installing the new one?
For any one who is interested in doing this mod you can get the LT part from Tasca for $42.00 and it comes in black or tan leather.
Originally Posted by 05RedFX4
The swap to an LT handle has been done before, it's a fairly straightforward swap, just one screw, on 07's anyway. The 04,5,6's had a different shifter design between the 150's and the LT's and in 07 ford put the same shifter tower in both, so now the LT handle bolts right in.
Originally Posted by black07screw
anyway someone can post some sort of picture of this, and the new lt shifter thanks
Originally Posted by LARIAT CHROME
My chrome cap does not want to come off, is it glued on? How hard do you have to pull on it as I don't want to damage anything internally.
EDIT: DO NOT pry off chrome cap, no need to, you may break it.
I just installed my LT shifter handle, the screw is under the button. It takes a T-15 torx bit. Put the shifter in L1, pull outward on the bottom of the button so you can get a small flat screwdriver in there and pop the button out, don't damage the button, you have to reuse it. Now remove screw and lift off handle,no need to pry off top cover. Slide new shifter on, replace screw, pop button into clip, your done.
Originally Posted by Mongo84
Do you have a link to the part, i can't find it...been looking to replace mine for a while now.
5L3Z-7213-T
Just copy and paste into the search by part # on www.tascafordparts.com
When it asks for make, choose lincoln, cause the handle does not show up under ford.
This handle will not fit the 04-06's without modification. It's a bolt-on on 07-08's
Resurrected an old thread, I know, but....
I'm thinking of putting the whole shifter assembly (tower and ****) from an '05 into an '08. Should the tower and everything work in my truck? I'll need to buy all the linkage cables etc...are the cables interchangeable between '04-'08, or are they split into '04-'06 and '07-'08?
Any help would be great
