Trip to Colorado and a Few Issues **long**
I'm going to share a recent experience with everyone. I just took a trip to Colorado to go snowboarding at Copper Mountain with some of my family. Overall it was a really good trip. Some of the issues that came up I wanted to share so if someone else is in the same shoes as me maybe it will help them?? lol
So last Wednesday I made a trip into town to run a few errands, everything starts out really good. I've had my lift on for 2-3 weeks already. I decided for the trip to put my stock 17" wheels and tires back on for better fuel economy / smoother ride / less noise.
Issue #1. The first issue I had is that after the lift has been installed, the stock wheels and tires rub when trying to turn. The outer tie rod ends would rub against the inside lip of the wheel. So my turning ability was greatly limited. The pro comp lift has you rotate the outer tie rod end to the top of the spindle for less of an angle. Not a huge issue - just have to watch how you turn.
Issue #2. Second issue, after running a few errands, I return home, pack up the truck with my gear, and leave to go pick up my uncle. A 1/2 mile down the road, I start getting a really bad grinding noise up front that sort've goes away when put in 4x4. So I call the dealer, they said bring it right out they would get to it right away. I pick up my uncle and cousin, head out to the dealer, 1 1/2 hours later they had both front hubs replaced. Both of them had cracked and were leaking vacuum which was causing them to try to engauge. So after a 2 hour delay, we are finally on the road!
Issue #3. The next morning early we woke up to 2-3 inches of new snow on the ground. Started heading up to Copper mountain and throw it in 4x4. There is now a vibration/griding type of noise that occurs!!! I was afraid of breaking something so I used it really gently. Got it looked at when back home. Turns out to be the front driveshaft causing the condition. So I followed fabtech's instructions and had the front driveshaft keyed, put in phase, and rebalanced. Now the vibration and noise is gone and 4x4 is good to go!! So for anyone with the procomp lift kit - I highly recommend getting the front driveshaft fixed. It is not a good feeling / sound when it is acting up.
Other than that, it was an awesome trip. Boarded for 2 days with nice weather. Fought a really really bad headwind the whole way back to Nebraska. Averaged about 15.5 mpg on the way home.
Sorry this post is so long - hope it may help someone else out someday.
Originally Posted by risupercrewman
That is precisely why I would never lift a new truck!......
OP, glad to hear you got to get in on some of the snow here
well im pretty sure your procomp kit says stock wheel backspacing is not enough, thats why you rubbed, and being a 6" lift im pretty sure it told you to cut the master spline and rebalance the front driveshaft...
did you install the lift? either way whoever installed it probably messed up the IWE's otherwise no liftkit can cause both IWE's to go out... btw if it isnt installation related, the problem might come back again, it could be a vacuum system problem
I did install the lift myself. It is totally possible that I could've messed up the hubs. I followed the instructions to a T including torque specs and everything. I had been driving it for 3 weeks before my trip so you would think they wouldn't acted up before that but anything is possible. I know they tested the IWE solenoid but my '07 already has the updated solenoid and it was working perfectly when they tested it. Still working perfectly good since last week when they replaced the hubs. So far so good!
Originally Posted by duece212
Mine only has 3000 miles on it and the lift goes on in a few weeks. I say do what you like and do it quick, you never know what tomorrow may bring...or take away from you.
The only thing that will be taken away from you is factory warranty coverage!......
I'm also not afraid to push the issue if a dealer declines service for a warranty issue when its not caused by the modifications.
Its definately taking a chance though, I give you that. I'm not going to let that stop me from enjoying my vehicle as I see fit though. Others are more conservative than I. (read that as smarter if you wish)
Originally Posted by Yamaha YZ 250
Picture proof...ProComp> Fabtech
If you ask me, Fabtech is much better in quality, and for what, a $100 more?
Either kit is the cheaper version of good kits. If you really want quality, go with Camburg, or go with CST, or better yet, go custom.
(and I am really not trying to **** off all you pro-comp owners. If its a street queen, then you have the right lift. If not, there are some small things you can do to improve your off-road chances.)
* all my opinion
** no matter what kit you run, something will break. Its part of the "fun" of off-roading !
