How do I remove ball joints from the lower arm?
i took mine out with the remover tool and a good impact, with the truck on jack stands i didn't have enough room to put the new ball joints in with it. so i took the control arms off and put it in my hydraulic press. could of used the c clamp to put the ball joints back in, but the press was faster and easier.
autozone loan a tool
Good info. Thanks.
Easy to do with a ball joint press. Auto Zone loaner tool Or . I purchase this tool At Harbor freight.
http://www.harborfreightusa.com/usa/...o?itemid=38335
Aww... that's very helpful. Pops out the bottom. I guess the gun will screw off the nut from the joint a lot easier cause it might just spin if done with a hand wrench?
Dude you can't brag about that unless you do it for me too.
