K&N Drop in Air Filter... waste of money?
I just bought a K&N drop in air filter for 40 bucks, as opposed to 11 for the Fram. Did I just waste my money, or is it actually worth it? I'm not looking for performance gains... really I just did it as a futile attempt to save any gas that I can.
Also, what are some preventative maintenance things I can do to increase fuel economy?
That's good to hear. I might switch to the K&N FIPK sometime in the future. The only other thing I can think of to save gas is to cut out my floor panels and turn my truck into a Fred Flintstone mobile... Or get one of those "as seen on TV" Tornado things
Yeah, He's right on the oiling right part, however most never do it correctly because of time constraints. The placement of the MAF on these trucks is BEFORE the filter anways, so you'd never have to worry about it. However, if you've seen some of the latest filter testing done recently, you'd wouldn't run anything but an AEM dry flow filter. There is a reason why all the guys in the desert are running their filters out in the Baja stuff.
Whether or not its a waste of money really depends upon how you look at it. If you are only look at increased horsepower and better fuel economy, then yes, its a waste of money.
However, look at the money you will be saving in the long run in filter replacements. Motorcraft air filters go for about $25 and even if you went cheap and bought a Fram you would still be spending $20. So basically, after 2 years the K&N pretty much pays for itself.
Personally, Im not a fan of K&N. I had a K&N drop-in filter in my truck and I ended up going back to a paper filter because of how poorly the K&N fit. You have to be really careful when installing the K&N, otherwise it wont seal properly and it will allow dirt into your engine.
You also have to be careful not to put too much oil on the filter when you reoil it, otherwise it can foul out your MAF.
For those reasons, I prefer to use the OEM filter. It costs a little more, but IMO its much less of a hassle. I just replace the filter once a year. It takes about 5 minutes to replace and to me its just much less of a hassle.
