F150 decals
Old 05-25-2008, 06:33 PM
jamieFF's Avatar
F150 decals
Does anyone know how to remove the F150 decals on the side of the truck? Are they double sided tape ? When I am doing my detail I was planning on removing them because one has lost its colour already anyway. Just want to make sure that after I have it off that there is not a hole behind it like the one on the back.
Old 05-25-2008, 06:43 PM
blackf150lariat's Avatar
yes 2 guide pins doublesided 3m tape
Old 05-25-2008, 06:56 PM
jamieFF's Avatar
so there will be 2 holes left from the guide pins ?
Old 05-25-2008, 07:12 PM
blackjack8900's Avatar
Yes
Old 05-25-2008, 09:47 PM
05BlackFX4's Avatar
yes, 2 holes will be left over...
Best bet is to take a blowdryer/heat gun and some dental floss...heat it up, slide the dental floss between the badge and the truck.
Then use 3M adhesive remover to get the glue off and then make sure to wax after the 3M is applied
Old 05-25-2008, 09:50 PM
The fender badges have pins, the bed side decals do not.
Old 05-26-2008, 01:10 PM
mkinttrim's Avatar
Dental floss breaks kinda easy, If you have some 20lb fishing line it works good!
Old 05-28-2008, 04:20 PM
4.2shorty's Avatar
i was planing on doing this until i found that they left holes in the fender.
what im trying to do now is find older f150 badges (1990-era) it's in a different font and it's metal instead of plastic. they'll look neat and cover the holes. at least till i have enough money to shave the handles, then i'll shave those at the same time.
just my 2 cents
Quick Reply: F150 decals
