DJM install... Struts???
ok guys im about to go out and install my DJM drop. now the question is.... how do i safely remove the springs out of the front??? i have dealt with regular springs in multiple different vehicles but i have never messed with struts. i have looked at some people installing this kit on the internet and it seems as if when the front suspension is at full droop the tension on the spring/strut assembly is relieved??? im just thinking to myself that cant be right. they must have skipped a step. sooo
how should i remove the spring/strut assembly from the lower control arm safely???
To remove the struts from the coilover assembly you'll need a spring compressor.
Edit: Stealth beat me to it.
Don't you still need to take the coilover apart? Or are you getting a whole new coilover? If you have to take apart the coilover than the only smart way to do is to rent a spring compressor or buy one. I was able to buy one super cheap and I've used it probably 10 times since than so it's paid off.
