Whipple, KB, Saleen FX2!?!?
#35
#38
#39
the Rouscharger I have can output 20 psi according to Roush if you have the proper pulley and crank pulley setup
#40
I will most likely want to run around 20psi when i get the motor built. however it would just be nice if there was a larger displacement blower that would work more efficiently at these higher psi's.
The roushcharger is an M112 blower that is used on the stock lightnings i believe.... The roots style M112 from what i have research does not like performing at those high numbers without sending IAT's through the roof... hence the nickname Heaton....
#41
Driveable, reliable, yet monstrous when called upon.
#44
MattFX4, Drew and a few others are running roughly 500 RWHP with 10 psi or less on essentially stock motors. Just simple bolt-ons and they've got it reliably...that's roughly 600 crank HP
I have issues keeping the tires planted right now with my 412 crank HP...I cannot imagine having another 200 wheel HP...and you want 20 psi?
