A 93,000 mile plug change success!
I almost don't belive it myself. I keep thinking I'm going to wake up and realize it was all a dream. But I have the old 2-piece MC plugs stitting right next to me. ALL STILL IN ONE PIECE!!
After hearing all of the horror stories, I was dreading changing my sparkplugs. I put it off for about a year and a half until I told myself, "quit being a p*ssy! you might have to pull a cylinder head, so what?" It was my way of working up the courage to do it.
I prepared by buying the champion 1 piece plugs, and the Lisle removal tool (I really didnt want to pull a cylinder head) I ran a double dose of seafoam in the gas tank, and added .5 degrees of total timing with my edge tunner.
The big day (today) finally came. I ran the truck hard for a few miles. Then I parked it in my buddy's garage and got to work removing the battery and PCM while the engine cooled. I removed the Coil packs and anything else that was in my way of getting a straight shot at the sp holes with my socket. I blew the holes out with compressed air, and loosed the plugs about 1/4-1/2 turn. I then filled the holes with a few shots of B12 Chemtool carb and choke cleaner.
Apperently the head were still a little warm because the cleaner started to bubble out of the holes. I figured as long as it didn't flash, it wasn't a bad thing for it to bubble. I waited about 10 mins and I decided to work the plugs back and forth slightly to help the carb cleaner weep down to the grounding sheilds. I worked one plug back and forth and it really didnt make a difference. So I decided to tap the plug/plug hole with my extention and socket, thinking the vibrations would help. WOOT WOOT after about 10 taps I tryed turning out the plug and it turned very easy! Whenever it became difficult to turn I gave it 10 more taps, and I was easy to turn again! I had to turn a few of the plugs back in a 1/2 a turn or so but tapping inside the plug hole made a huge difference!
Pics of old plugs are in my album. Sry for the quality.... camera phones have a ways to go... hehe
One more sparkplug change success story.....with over 20K miles lol
i didnt mean to rain on your parade, but i dont care much for champion plugs...
https://www.f150online.com/forums/en...ent-plugs.html
and some champions out of a ninja:
and thats just information ive run across NOT looking for information on champion plugs.
Awesome you got your plugs out, I know it is a great feeling (I broke 3). However, you may want to do some research on Champion plug, I think they should be left in lawnmowers. NGK is coming out with plugs for the 5.4 soon, and Autolite has a plug for our engine but still the 3 part plug.
As long as you have the antiseize on the plugs you should be fine, even with factory 3 part plugs. Check them every couple years, clean and recoat.
