Bilstein Q: AS write up, Up or Down?
I did more and more searching because this is such a 50/50 topic.
https://www.f150online.com/forums/20...questions.html
Post 10 the guy verified with them...
Picture this. You go through a mud bog and the boot gets filled with muddy water. It leaves behind a glob of mud that sticks to the body right at the opening of the shaft and throughout the boot. As it dries, it cracks, leaving dirt inside the boot.
Now, imagine the boot on top and the water drains along with most of the mud. As dirt cracks, it drops out of the boot and finds it way off the truck. A simple power washer can remove most of the remaining dirt and mud. And since the body is tapered, it will allow proper drainage of any sludge from the boot. Gravity is also on your side.
Would you think this to be a better idea all around?
If the body is up, dirt and mud can get trapped in the boot/cup which will kill a shock faster than anything else. The hydraulic shaft is meant to be as clean a possible.
