Big block swap
Big block swap
I asked this question on another site and recieved some good suggestions.....so i wanted to ask here too.
My truck is a 2004 f-150 ext cab 4x4 4.6..... I plan on swaping in a big block 460....why u ask?? Lol.....well i already have the engine and a good friend of mine will be building it....the motor should be pushing around 750hp....the truck will also be lifted and on 37x14.5x22 tires....my main concerns are motor mounts,headers,clearance and strengh of the frame itself....if any of you know a project like this or have any suggestions i would really like to hear your input....this project is still just in the planning stages but i really hope it can be done without having to customize everything!!!!.......thanks for your help....kenny
Don't know where you live, but in this state you would never get that thing registered. There is no way in Gods green earth that anyone within the borders of the state would pass smog on it... no pass smog... no registration. Every single thing on that truck has to at least meet the standards of the vehicle when it was produced (in '04). You intend to insure it? Good luck! No agent in his right mind would write the policy on it, he'd lose his insurance license for sure.
Like everyone has said, unless you plan on towing it to every mud bog or trail ride you go to, you won't be able to get it anywhere. Just the motor swap alone will be enough to make it illegal on all streets and highways.
The only motor swap you could do legally would be a 5.4 or 4.2 swap. IIRC the only motors you are legally allowed to swap in must be available, on the same model of truck, in the same year your truck was built.
It sounds like a sick project, but there is still a lot to be considered. Keep us updated with what you're doing
http://www.fordracingparts.com/parts...KeyField=10261
This one bolts right up but will require a few electronic adjustments. You can find it for around 15K if you shop around.
But bear in mind your drivetrain will cry.
Technically what he plans to do is illeagal, but so is removing your cats, driving 56 in a 55, spitting on the sidewalk, and so on.
If he lives somewhere that does not require smog testing, he can do what ever he wants, who's gonna know. Here in Ohio, only Cleveland and the surrounding area require smog testing, the rest of the state, you can do whatever you want, nobody will know the difference.
