CV Angles Bad? Check the pics out.
Old 07-21-2009 | 06:47 PM
snotruck's Avatar
So I have the camburg coilover and the camburg uca. I am concerned though about my CV angles. I would appreciate some input on this. I have the coilover set to 2.75 inches right now. It clears the tires with no rubbing. I am though worried about the cv angles. These are pics without the current set up but the cv angles are the same.
Old 07-21-2009 | 08:11 PM
jdruzik's Avatar
It's a little steep, but not to bad...
Old 07-21-2009 | 08:14 PM
snotruck's Avatar
Thanks jdruzik.
Think I should lower it down to 2.5? Then I might run into some rubbing issues then with the tires.
I just don't want to mess up the CV axle is all. I do have an extended warranty through a company called the mechanic.
Old 07-21-2009 | 08:39 PM
sbchris's Avatar
If the cv's are binding it would be bad. I doubt they are.
Old 07-21-2009 | 08:48 PM
snotruck's Avatar
I don't think they are binding. It works beautifully in 4h and in 4l.
Old 07-21-2009 | 10:59 PM
Impact9's Avatar
man that is pretty steep. Well the good thing is the more bumps you hit the more often you'll be in specs.
Old 07-21-2009 | 11:52 PM
GTRider245's Avatar
I would back them down to 2.25-2.5
Old 07-22-2009 | 12:22 AM
snotruck's Avatar
The thing is if I go lower, even about 1/4 of an inch I might get rubbing. I already have bent some metal and trimmed a lot. I have rims that are 4.5 backspacing in a 305/65/18 tire to clear the camburg upper a arm
Old 07-22-2009 | 08:33 AM
yetti96's Avatar
So you have a camburg UCA? So does that mean no more ball joint or does it have one?
Old 07-22-2009 | 11:42 AM
snotruck's Avatar
No more ball joint. Its replaced by a 1 inch uniball. So much better. The angle is gone.
Old 07-22-2009 | 11:55 AM
yetti96's Avatar
Ok good, I wasn't sure what kind of joint it was (heim, etc) but I would say with CVs at that angle, a BJ up top would be feeling some pain.
Old 07-22-2009 | 12:07 PM
Indo's Avatar
Don't forget about them settling a bit.
Whuddup Chris.
Old 07-22-2009 | 01:47 PM
mSaLL150's Avatar
Those angles are pretty bad.
Old 07-22-2009 | 02:19 PM
Ftruck05's Avatar
Those angles do look steep but if there is no binding it should be fine. Here's some pics of what they look like with a 2.5" level.
passenger
Driver CV angle
Old 07-22-2009 | 02:36 PM
Not on the rebound. Offroading could pose issues IMO.
Quick Reply: CV Angles Bad? Check the pics out.
