Pallet + Line-x/Rhino
Never used it in a truck bed. But did use it to do the floor, inner walls, gas tank skid plate and some other random stuff when I had my Wrangler. For that it held up and looked great. Was farily simple to do to. Just don't get it on anything you don't want it on.
I also used it instead of buying sill plate protectors. I taped off the areas I wanted covered and applied. No tape or glue to come loose over time or junk getting under a plastic part! Worked and looked great too.
As for company done one, had an Inyati in my GMC, not happy with the fading of it. Would have been fine for a concealed one but this came over the bed rails. I have a drop in now and will keep it till its dead then do a Line-X. The only reason I don't do it is that it has the permanent bed caps so I am not worried about the bed liner rubbing on exterior paint. Its a truck bed, use it like one!
Spray in liner is the way to go but if you want to save money and DIY I would grab the new Dupont Bed Armor with Kevlar:
http://www.bedarmor.com/viewer.php?filter=r&cat=
Herculiner....
Coming up on the tenth anniversary of the Herculiner Hootus
http://www.explorerforum.com/forums/...threadid=18595
Herculiner....
Seems like that might have been true about the wate on previous years, but the 04+ trucks have gaps in the truck bed that would probably allow the water to drain out. I could see it happening on older models though.
Herculiner....
Holly ...Not the Hootus thread. Man it's been years since I read that and I can't believe it's almost 10 years since the original poster posted and he is still online. That thread is a classic!
Last edited by Bluejay; 04-15-2010 at 04:18 PM. Reason: Do not circumvent the language filter
Whatever. I would not take a chance with the liner rubbing the paint off the ridges, myself. Maybe even rubbing a hole in one.
I Herculined my truck bed. It's a chore to do...especially the prep, but it's holding up well. If you scratch it, you can simply reprep and add some more.
I father has a Rhino lining in his 02 F350 and also in his old 05 F350. Both trucks got/get loaded with 3000-4000lb pallets almost weekly and both have held up pretty good. The pallets do get slid on the liner also, not just sat. I will see if I can snap a couple pics of his 02 this weekend, I think there may be 1-2 spots where the liner is missing from getting the tines of the pallet forks rubbed across a few times but that is it.
