2004 60k idles low
2004 60k idles low
Cold engine truck starts just great and idles at higher RPM until engine is warm. Then it idles down. It use to idle around 750-800 but now in gear it idles around 500 or less. I noticed as I come to a stop it gets really low almost like it is going to cut off but then slowly recovers back to 500. The engine does not hesitate in response. I cleaned my air intake sensor, KN air filter has been cleaned.
Any help would be greatly appreciated.
It needs to be cleaned on the bench with throttle body cleaner.
https://www.f150online.com/forums/ar...ttle-body.html
I think that's for the old mechanical throttle, but the basic procedure should be the same, you don't have a throttle cable to disconnect, just electrical stuff.
Well just got finished cleaning the TB with TB cleaner and also cleaned the MAF sensor with MAF sensor cleaner. The TB had a lot of hard carbon buildup above and below the flapper valve. After cleaning I could see more clearance between the flapper and the body wall. Installed new o-ring TB to Intake and put everything back together. I also removed my KN air filter due to having to oil it after cleaning. Read many issues on using this type filter. I installed a new stock air filter for now. I will probably get an AEM brute dry filter system later.
Now when I come to a stop in gear the engine never gets below 500 and recovers immediately. Fantastic. I did test it on quick stops with AC on and off. PASSED all tests. Thanks for all the help.
