HELP...Parking lot overspray
Trust me, ALL of the insurance companies that insure paint contractors KNOW that clay will easily take water based overspray off. Urethane or epoxy, DIFFERENT story, but water based is easy.
DO NOT USE ACETONE! Acetone is a fairly "hot" solvent and will damage your clear coat. (I used to run a painting department for a Fortune 500 company.) As other have already stated, a clay bar (with proper clay lubricant) will generally do the trick. If you're not comfortable with the process, take your truck to a professional detailer. Since the painters are paying for it, get it done right.
