2008 Fuel Tank
Fuel Tank
I have now had this truck for over a year now, and still dont think its a 30 gallon tank. All the information that I have found says its a 30 gallon tank, but I have never been able to put in more than 24 gallons, and I driven with the low fuel light on for at least 20 miles. It isnt a huge issue, but it still bugs me, I know I dont want to be pushing the truck to a gas station.
najerry, when the low fuel light comes on, the truck estimates 50 miles to empty. I have a Lariat which counts down the mileage to empty and have driven to 0 a few times. I have fit as much as 27 gallons in at a fillup. The last few gallons aren't what I'd rely on, but even at 0 miles left to empty it never stumbled or cut-out like it was low on fuel.
The low-fuel light and the gas gauge are calibrated to make you think you have less gas than you really do. It's a safegaurd to keep you from running the tank (and the fuel pump) dry. The display in my Lariat always says "50 miles to E"when the low fuel light is triggered.
you have to remember though that the distance to empty is calculated off your mpg, so the worse mpg your getting, it will tell you your empty sooner than if you were on the highway. the fuel light comes on whenever it gets to 50 miles to empty, not when it has a certain amount of fuel left. no idea how it judges that on xlts and the like with no distance to empty thingy.
also, the gauge is pretty accurate, when the light comes on im usually at like an 1/8th of a tank IIRC.
i have a screw 5.5 foot bed with the 30 gallon tank by the way. i have my window sticker.
top gear even did a special, they drove 700 miles, jeremy clarkson was in a twin turbo jag that he knew wasnt going to make it, and it made it all the way there. the other 2 guys drove little hatchaback diesels, and they made it too. all of their trip computers said 0 miles to empty for a long time.
hell in my 01 grand cherokee i had, i could run it 20-30 more miles after it said 0 miles to empty, and it wasnt sputtering or anything.
fill a 5 gallon gas can and strap it into your bed. go drive until it starts sputtering. then pull over, and put all 5 gallons in it and get to the nearest gas station, and fill it. i guarantee it will take 25.1 gallons or something like that (because youve already put in 5)
not you in particular but if someone really didnt believe it, try it. that or run it down to 0 miles to empty then go fill it, it would probably take 25 gallons or so.
