Vibration Problem
Vibration Problem
I have a 2004 F-150 FX4 with 70,000 miles and I am having vibration problems. When I pull out with my whells cut left or right it vibrates in the rear end. If i pull out straight i have no vibrations. Just with the wheels cut. I have noticed that it only does it after I drive it a couple of miles. its like when something gets warm it starts doing it. I have had the rear end, transmission, front end , and transfer case checked and fluids changed. If any of you all have had this problem please help me. this is so aggravating. Thanks
Mine started doing that a little while ago and it only happened every once in a while until this morning. My transmission went out in the way into work. I started looking into it more and the 2004's have a transmission problem that starts around 77000 miles and goes out sometime around 90000. You can google it and see that there are a lot of comments about it. Ford denies that there is anything wrong and it's not a manufactor issue. If I was you and I wish I knew sooner take it and get it looked at as soon as possible or your gonna be out 2500-3800 dollars. I'm speaking from experience.
