Spark Plug Lawsuit ?
Well we could all crawl under a rock and ignore it, pretend there isn't a problem here? Or we can continue to bring up the issue and try to push Ford for some assistance with it?
Your choice, your money out of your pocket when your plugs break, which by the way is pretty much unheard of on just about every other vehicle out there.
If you want to believe that one day Ford will cover any of the cost of a problem that's been fixed since 2007 that's up to you.
You gotta believe in something.
I have no illusions that Ford would ever fix this issue. But if people stand up and push the issue maybe Ford will take notice and next time something like this comes up they may re-think there position on it?
Not trying to be an a$$ here but really, It's a internal combustion engine. How many years have they been around? General maintenance items, spark plugs, air filters, oil filters, etc. should be a no brainer and should be something any home mechanic can do with out worry.
A 50% success rate is not acceptable for something so routine.
Ford did their job. Yes, they had a pretty weak design, but they fixed this. They have provided engineering solutions and supporting documentation. They have designed tooling to aid in broken plug removal. They have provided practices, and improved them along the way, that allows for plugs to be removed again reduced chances for breakage. What more do you folks want?
The thing I find most interesting, is the extreme fear factor that exists with those who have only read about this problem. It's typically, not a huge deal. If you're reading this, you're more then likely aware of the 65 dollar Lisle extraction tool. With this or one of the other tool manufacturer's extraction tools, you can rather easily get the job done. Heck, I just changed my motorcraft plugs out on my 07 this past weekend. The whole job, including the TSB pre-soak, took 1.5 hours. No broken plugs. And yes, I broke 3 when I changed the factory plugs, but the extraction tool did it's job then.
So face reality folks, this typically, isn't a big deal.
Beside spark plugs can hardly be called "general" maintenance. You replace tires more often than your plugs.
[QUOTE=svt2205;4345351]Ford did their job. Yes, they had a pretty weak design, but they fixed this. They have provided engineering solutions and supporting documentation. They have designed tooling to aid in broken plug removal. They have provided practices, and improved them along the way, that allows for plugs to be removed again reduced chances for breakage. What more do you folks want?
They fixed it for the new customersm LOL!! ( what more do I want) ??? A plug change were im not gambling on my daily driver that takes me to work..
So you think that we should be using the same old designs for years to come? No progress, no increase in efficiency, no increase in fuel economy or decrease yearly maintenance costs. Don't fear change brother!
Is called R&D.. And if they sell a product they need to stand behind it period!! so maybe ford with all the negativeness on this issue should hold Honeywell for this problem.. i should not have to deal with it...And if ford didn't think it was a big deal why did they change it?? why not just get a new spark plug design?
This really is a non issue now anyway. Ford has released TSB info and specified removal tools to make changing plugs simple. Most of the time plugs are replaced without a hitch. When there is a hitch the means of removal are there.
No more reason to fret, unless you're scared.
My wisdom comes from experience. If more people spent more time figuring out solutions to their problems instead of whining and complaining about the problem the world would be a much better place.
