cb mount options with low profile toolbox. no mag mounts.
any used this kinda mount
http://www.walcottcb.com/firestik-ss...l?cPath=28_353
to mount a firestik or simmilar ant. to, im getting a low profile toolbox i believe, and want to mount it towards the front of the bed, not off the back of the toolbox.
anyone have pictures of either way?
that flat bar mount im guessing can be mounted to the underside of the toolbox poking out the side, so its sandwiched between the box and the bed.
how would the ground wire run?
what did you search for to find that. im wondering what makes that sit flat since that bar is 2mm thick, and how long it has to be. the firestik brand one is 5 inches long. and then wondering where i would run the cable. no one in this section has a setup like this?
im leaning towards mounting it to the back of the toolbox on the inside of the bed, since it would be less likely to grab trees and such i think.
Yes. It needs to be longer from the stake hole to the stud mount for the antenna. When I installed mine it looked fine until I went to mount the antenna. Since I dont have a tonneau cover or toolbox yet I just flipped the bracket around so that the antenna sits on the inside of the box.
sorry for taking so long on the pics but been busy with work. this is just a temp mount for the antenna i came up with just to see how good reception id get so far i like it. im thinking of ordering this one http://cgi.ebay.com/FireStik-Door-Ed...6#ht_719wt_856 and modify it some also thinking of a spring on the bottom of it just so it can bend a little still not to sure.
hope this helps some.
i own this mount
and im getting that low profile toolbox, i have to mount it to the back of the toolbox like next to the handle. and ill be putting a 4ft firestik on it. would you rather mount it to the back of the box, with the mount i own, on the back side, or would you get this mount
and mount that to the side of the toolbox so it wraps around into the bed (ant. still on the backside of the toolbox). i would think the last mount i linked would hold the ant. more steady. and then if i ditch the setup, i wont have holes in my toolbox that are visible from the back.
which way?
which way?
