truck not running good after spark plug change
so i changed the spark plugs this weekend because i was getting codes like random engine misfire cylinders 3 5 and 7 were bad the truck has 120k on it so after i did the plugs i had some V10 coil packs from a buddy i put on the motor ran very bad and would stall out so i put on my old coil packs started it up and it ran much better for about 45 seconds then started running bad and stalled again now im getting new codes P0204 (injector circuit malfunction) P0356 (ignition coil F primary/secondary circuit) and P1233(fuel pump driver module offline) which that code has been up for a long time now any help would be very useful thanks
Maybe it was really code for titan357.
That means you need to give me that truck.
I don't know man, sounds like you should just reset the ecm and go from there.
