Oils?
7 quarts in the 5.4L (on my 06 anyway).
just stick with the motocraft fl820s filter and 5-20 syn blend branded oil and filter. they recommend you run it for 5k.
you can spend the money on mobil one and a better filter but really its not nessicary. i couldnt bring myself to run oil for more than 5k anyways.
do it at an even numbered mileage. i do mine at 50k, 55k, 60k, ect.
You can use any quality 5W20 and quality filter. However, the Motorcraft oil and filter is the most cost-effective.
To the original poster: This is a question that is constantly asked here - don't be personally offended if people get a bit short with you. If you use the search function, you will probably find 1000 threads all asking the same thing.
